1 - 3 of 3 Posts
Hey Everyone,
So was looking around today for a aftermarket version of the "clutch holder" part 13280-0105 that allows you to bolt it on the handlebar like the front brake resovior does instead of sliding the holder across the handlebar to install.
Does something like this exist?
If not, I was looking at combining the below two products that represent the below image. Essentially, cutting half the circle of 13280-0105 off, welding 2 blocks of metal on the top and bottom, & creating two threaded holes that would mount up to 43034-1016.
26735
But hey, if someone already made something similar then that's even easier. 馃榾
1FNGR has 1 & 2 finger pull levers that clamp on.
Hey @Kaw'ee
I just purchased the below lever set from them today actually so funny you mentioned that.
Z125 Easier Pull Clutch Lever +Brake Lever Combo | "Henge" Lever
However I will be without a left mirror going with this method... Still will be on the lookout for a module version of part 13280-0105, and perhaps look into reverse engineering the existing one.
1 - 3 of 3 Posts
