21 - 40 of 48 Posts
Discussion Starter #21
Very cool! Are you having any issues with the wiring jumping around when it hit the throttle? The magnetic impulse can do funny things.
I haven't noticed anything like that yet, but then again I haven't ridden it much yet. Will report here if I do!
Discussion Starter #23
100 mile update: still fun!
Everything is holding up well so far and I rode back and forth to work a few times last week. A few thoughts:
  • It is definitely faster than the stock Z, but certainly not crazy fast. Acceleration is faster and I can hit 60 mph without much trouble where as I felt like it took a lot of runway and a full tuck to pass 60 with the engine. I am still messing with the controller settings for throttle timing, max current draw, etc.
  • The weirdest thing is lack of noise. It is totally silent at all speeds and just smoothly pulls you up to speed without interruption.
  • I'm not exactly sure what my range is yet since I haven't run it all the way down to empty. I have an adapter that lets me use the J1772 chargers at work so it has been easy to stay charged.
  • I am probably still being more timid than I was on the stock bike since I have this tiny fear in the back of my mind that it will all just fall apart (and then catch on fire)... hasn't happened yet, not even once! But I think I will get more comfortable and push it harder as I ride more.
  • Having a reverse gear for backing out of parking spaces is pretty cool, even on a bike this light.
This week, I also received my load cell amplifier so I got the rear brake load cell wired in. This actually feels fantastic, hard to tell it isn't a real mechanical brake and I know it is improving my range. There is no "engine braking" so you feel like you are coasting forever until you engage the rear brake regen.
The bike still looks bad because I can't get the fairings back on until I reattach the fuel tank. I think I want to mount the charger inside the tank, but there are a few things to figure out first.
Discussion Starter #25
I got to work on the onboard (tank mounted) charger.
The first step was to cut the bottom out of the tank. The cut isn't very clean since I only have a dremel, but I filed down the sharp edges and you won't actually be able to see this side of the tank anyway.
Then the charger fits inside (barely) and is fastened with square U-bolts to a bracket spanning the opening. For the picture, everything is in there temporarily since I want to add some foam padding where the U-bolts clamp and also run a bead of RTV around the opening to further soften the edges. I'll cut off the excess U-bolt length after that too.
I like how it looks from the other side. This is a J1772 connector which I have at the charging stations at my work. I was able to fit the stock silver trim ring around the plug housing.
Once I get this finished and re-install the tank, I'll be able to put the fairings back on and this project will be pretty much wrapped up.
There should be a few other sizes of that stuff, if not you can order what you need online from a bunch of places. You can get it in black rubber, black nylon, white nylon, and probably a bunch of PVC plastics too. You might find it in the electrical section of big box home stores, used as edging for electrical panels when you use a knock-out.
Discussion Starter #31
Exciting milestone today! I reinstalled the tank (now with the charger inside), then reinstalled the fairings. Here's how it looks all buttoned up and plugged into the charger.
I'll try to do a full "walk-around" video maybe next weekend.
Wow. Not that I know you enough to doubt your talents, but that turned out awesome. Almost looks factory! I just think it needs something to break up the battery cover... maybe a Mr Fusion logo/sticker?
Awesome to see it all together. I really dig the charge port in the old gas cap visual, very funny. The open battery space could also be a good place for your new Z000 Amateur logo.
Or alternatively save yourself a bunch of questions...
"Yeah, it's electric!"
"No I won't build you one"
Congrats!
Thats just nuts Andrew :surprise::surprise::surprise:
Awesome job :wink2::wink2::wink2:
I'm currently on 6 different Z125 forums/sites and would love to share a link to your build from the start but feel like I'd be stealing your Thunder.
This needs to go Viral ....................
Theres only one z125 forum :p
This looks ridiculously sweet.
Does the box bottom out going over some bumps?
That's incredible. As Jay Leno once said: I'll buy it! I'll buy it! :D
Looking forward to the video and curious about range, etc. , total part cost and most importantly, when are you selling kits? ;-) or I can just hand deliver a stripped ready to rock Z for the electric nature haha..... but I really would love to own an electric version someday seeing as it being a realistic possibility.
21 - 40 of 48 Posts
