Love it. Keep us posted in this thread on this Winter work program.
Will do. Removed the engine from the frame last night, and some might be interested in how I did it. See attached photos. Went on Amazon and got an appropriately sized jack lift for 65 bucks. Works great for this size and weight engine. Since there are only 3 hanger mounting bolts, a little upward pressure allows you to simply pull the bolts out by hand after removing the nuts. Then lowering down slowly allows you to check and make sure you have really disconnected and removed all cables, tubes, etc. This way it’s quick, efficient, and safe on the back muscles to do by yourself. Also, it makes installation easy as well - just crank back up and align as you go. Notice I chose to leave the throttle body and injector connected to the bike. Since the engine drops down and away from it, why bother disconnecting everything when it has to come off the engine on the bench anyway?
Another suggestion is, especially if you are like me with lots of mods and cable/tubing reroutes not in the manual - take lots of close-up cellphone photos before you remove stuff. Makes for an easier time in reassembly.
Engine is now on the table and first inspection shows me the gasket leak area on the top of the crankcase, the initial reason for doing this winter work. I also see evidence of some slight gasket blow-by at the base of the cylinder in an area I couldn’t see when on the bike. This I’ll look at carefully when I pull the top end.
Again, another reason I have this bike is that it’s so easy to work on. I enjoy doing this almost as much as riding it. Almost... :wink2:
JW
