221 - 231 of 231 Posts
Installed a slim control unit to make room for the handbrake lever. Everything works except the high beam. I'm using an AOLEAD h4 LED. The high and low beam works with the stock control unit, what am I doing wrong?
25492
where/how did you connect wires. got pic of inside switch.
I'll take one tomorrow but pretty sure I got everything correct. Lights power on, but when I press high beam it turns off so I'm assuming it's the connection or it's wired to interrupt signal. I reversed the leads while keeping power wire wired and neither lights come on with click of low or high beam.
Reason I feel this is correct is because from the stock harness, if you touch orange power lead to the stock gray or green it makes signals work, respectively.
Trying different Paint ideas :unsure:
Gonna do something more the headlight... Then paint the other side tomorrow ;)
After playing in paint last night I Couldn't make the headlight blend, so leaving as is and going to order the KRT green top tank shroud and re-do the tail cover paint for more green..
Edit: 7-27-2020 Other side today with new tail cover change
Just Installed a New Prototype Product by Kawasakibrad.com today :cool:
I will be testing it for a couple of days and returning a successive report I'm sure
Everything I've tested for him has worked perfectly and is still working (y)
Great to have someone inventing much needed unavailable parts for the Z125 Community ;)
What is left stock on your bike to modify?
I'm going backwards :LOL: ... Put stock DFI back on to test new part....
