1 - 12 of 12 Posts
After doing a lot of research and looking at a bunch of aftermarket LED replacement turn signals I looked into just replacing the bulbs. As a lot of you know already you need to add the LED flasher relay or you get the "hyper flash". The other problem is that the factory turn signal indicator in the dash pod will not function if you go this route. I wanted to keep the stock turn signals as they are spread out more and wanted them for the visibility and safety reasons. So I pulled the trigger and ordered the Inertia LED replacement bulbs. These are canbus LED's meaning that they draw the full 10 watts just like the factory incandescent bulbs as they have an integrated resistors built into the PCB board. No need for an LED Flasher relay, turn signal indicator works in dash pod, and they are 700 lumens and very bright. They are pretty expensive ($50 a pair) but have a lifetime warranty. I would highly recommend them if you want true plug and play function as stock and have the added safety and visibility of the added brightness of the bulbs. You can order them through Amazon also, but were out of stock when I went to place my order. So I just ordered them directly from the manufacturer. The company is Inertia LED. I would have provided a link, but I don't have enough posts to do so yet!
This is what showed up on Amazon for me / Got a part number ?
Inertia LED RY10W, BAU15S, 7507, 12093NA Motorcycle Can-bus Amber 10W LED Turn Signal Replacement Bulb | 120 Degree Base Pin | 100% Plug and Play/Error Free
They look like miniature satellites , do you get better cell service (Lol)
FYI, the TST flasher adapter lets the dash work properly on mine.
Have not heard they figured that out yet :wink2:
All the original videos state they haven't figured that out yet .
Do you know if there is a new/different part number so everyone can make sure they got the ones that fixed that problem or did they just stay with the same part # / or maybe post up what you ordered and got ?
TST .... You here ?
Their website shows something a bit different.
Ya, it took me to PHIllIPS bulbs ?
Which ones did you get NfdBrian ?
edit / motorcycle guide gos to Philips / and shop now gos to type i showed .
Sorry, that was wrong... It is the Chrome Glow flasher adapter. I get three fast flashes with a pause and repeat. Electronic LED Turn Signal Flasher Relay for Kawasaki Z125 Pro
They claim normal flash rate, but that is not what I'm finding with front LED and rear incandescent. I may need to change the rear to plug in LED and see if the flash rate normalizes.
Yes the RY10W is the correct part number. I was going to originally order them from Amazon as that's where I actually found them. Unfortunately they were out of stock so I ordered them directly from the manufacturer. Like I said they are a little pricey, but very bright and lifetime warranty and plug and play!
TUINCYN BAU15S PY21W Amber 5630 33SMD LED Bulbs 900 Lumens 7507 1156PY Bright Brake Stop Parking Light Turn Signals Bulb Side Markers Lamp DC 12V 3.6W (Pack of 4) https://www.amazon.com/dp/B075B5KQCQ/ref=cm_sw_r_cp_apa_ekDABbFD256D4
That's what I am running and they are 12 USD for 4. They say canbus compatible but I noticed slightly faster flashing, not hyperflash, and the indicator on the cluster still works.
A much better option rather than spending 100 for 4.
Reactions: 502Z125
1 - 12 of 12 Posts
