What cam did you install ?
I'm guessing you got the TB parts cam TBW9210 kit (contains cam sprocket TBW0645 and cam TBW1431) if your still using the stock head ?
I have not seen this kit but noticed some possible issues that would be setting the valves on the Exhaust stroke if the timing gear was put on 180* out
www.z125owners.com
CAM question (TB)
Has anyone installed the newest TB parts cam TBW9210 (contains cam sprocket TBW0645 and cam TBW1431)? Website says remove the rear/right bearing for the z125 (RH side). I’m assuming the KLX has one and the Z does not since this cam is for both. I took the bearing off and it has a keyway where...
