1 - 3 of 3 Posts
New Zpro owner (2018 KRT purchased with 1k miles, Two Bros. pipe, and Bazzaz); my first modern mini but longtime rider (50+ years); casually sporty but hardly a knee-scraper (other current bike: 1st-gen 390 Duke).
I can already tell the little Kaw is going to be a lot of fun. But the first thing that needs to be addressed is suspension.
I weigh 120lbs. (5'8"), and although the roads here in the southern Blue Ridge have great shapes, South Carolina doesn't invest much in maintenance, so I'm really getting launched by mid-corner bumps. Most of the suspension threads discuss stiffening the stock setup, though.
Where should I start with appropriate suspension mods? Looking for best bang/$. The only things I've done so far are to make sure the shock preload was on softest setting (it was) and reduce rear tire pressure a couple pounds from spec.
I've seen threads here mentioning Grom-compatible shocks being longer that Z's, but another initial impression is that steering on the Z feels a little slow/vague (all that rearward weight bias), so it ought to benefit from raising the rear a little. Should I broaden the search to include aftermarket Grom shocks?
Also: for whenever tires need replacing -- any thoughts on which tires offer best ride quality?
Thanks in advance,
JLJ
I'd recommend Ohlins both ends, using the lighter of the included spring rates simply to control damping better. As for tires, there's a LOT of great options. The Michelin Pilot Pure is our top selling tire for all-around, non-race casual street use.
Can't go wrong with Ohlins, quality components. As previously mention Michelin Pilot Pure is a great tire, haven't has them on the Z125 yet but has them on a Vespa 250 and a Zuma 125, nice ride, good handling, and they are one of the lightest tires. They are also easy to mount. I went with Racing Bros shock and fork cartridges just to try something different, I'm on the other end of the scale and need stronger springs, changing the suspension mad a big difference. Head to the Small Bore Event at Barber Motorsports Park in Birmingham, AL and you'll see more of what's available. First weekend in June.
Best of luck
1 - 3 of 3 Posts
