1 - 3 of 3 Posts
Does anyone know what that copper looking nipple is for? I messaged the seller 4 days ago with the same question and received no response. I can't find another one anywhere so it's basically just curiosity now.
That's the Ca, model again.
The hose from the purge valve go's to it
It only has a .030 hole as is stock
I blocked mine with a rolled up earplug and vacuum cap off
Drill, tap, and put a set screw in it. If you use a taper tap, don't go all the way through. Then you have a taper to lock the screw against. Did this on my Buell because it kept blowing the cap off and causing a vacuum leak. Think I used a #4 set screw, but it might have been smaller.
[edit] That's really small! You could probably use a #2 screw or just clean the inside really good and stuff the hose fitting full of epoxy putty.
Could also zap it with a tig or mig to fill up the hole.
1 - 3 of 3 Posts
