1 - 2 of 2 Posts
· Super Moderator
Discussion Starter · #2 ·
Signs of a bad one-way starter clutch # 13194-0019
.. And/Or a bad Limiter # 39076-0022
Very common issue when you install a BBK top end without a de-comp cam
Bike will bump start and run fine but starter runs faster and sounds like something has stripped out
You can also draw a line across the 2 piece limiter with a permeant marker and turn the bike over and if the 2 lines are no longer aligned to each other the 2 piece design limiter is slipping. You can tack weld the 3 places shown without disassembling anything and try starting it again
You will need a rotor (flywheel) puller to the change the one-way starter clutch
TBParts #TBW1104
Font Circle Science
1 - 2 of 2 Posts
