1 - 20 of 63 Posts
My starter sounds like ****. Has anyone else noticed there starter just sounding like a piece of crap? I know if I take it to my dealer there just gonna say we'll that sounds normal. It's sounded fine when new, 700 miles later it's quite noisy
gut guess
something on the starter has a lot of friction
if its a bushing, it needs oil big time
I've worked on a lot of small motors like on fans, where they start screaming like that
one tiny drop of oil on the bushing they run silent for a while
that sound is bad, and not normal
I would take it in since you have a warranty
either something is binding somewhere, which is very bad
or the starter, or if it has a one way starter clutch is going bad
I would hate for anything to seize up and ruin the engine
or worse cause a crash
Strange how it whines when it is turned off also, any bike techs on here with some input?
Good videos you made. They make it possible for others to make a better guess. I think it sounds like the starter gears & pins are a bit dry and need some lube. They are still briefly spinning after the button is released, that's why you still hear the noise. Just take it apart, lube it all up and recheck it. Have you changed your oil yet? Fresh oil will help make everything inside the engine run smoother and quieter.
Discussion Starter · #12 ·
Just needed to lube the gear pivots with some moly grease. She sounds good now. Might a regular maintenance thing every time your in the side case it sounds like
Yes that's all they did. Noise has gone away. Didn't cost me a dime and you get a free oil change out of it. You can ride it as is and it won't hurt anything but I'd have it greased up when it comes due for fresh oil
probably smart to remember how many starts you do so if it happens again you can complain maybe get it replaced
50 starts is nothing with it happening so soon
so hopefully after 100 or more if it never comes back then could of just been factory assembly error
Discussion Starter · #18 ·
Starter noise has returned 4-5 starts since the dealers "repair". They keep trying to lube things and fix the **** thing, I'm pretty sure it needs a whole NEW starter. Dealers giving me the run around
Does anyone have this noise issue? It's also getting pretty hard to start at least 4-5 pushes of the button for it to start and that's even with the throttle twisted a little
Getting sick of the dealers BS does anyone have a spare starter for sale??? :p
Video link bellow
https://youtu.be/FgbaAKd1u7E
Just watched your new video then the original video and they sound very similar. If lubing the gears made the noise go away for a while it's odd that it's the same parts inside making noise again so soon. Has your oil been changed yet? Fresh oil wouldn't let the gears run so dry and noisy so it could be the starter motor now. It's fairly easy to pull it out and connect to a battery and see how noisy it is in your hand. It sucks that your dealer didn't fix it right the first time, but if the noise went away for them, they thought they were done with it. You need to let them know it's back and it now needs to be fixed, permanently. It will be covered under warranty again so take it back to them or a different dealer, if possible. I wouldn't buy a starter unless you have no other option. Mines never been that noisy and I don't think I've heard another like yours. I feel sorry for you, dude.
Video link bellow
Get behind the dealer to make it right. If he or she cannot, then you are well within your rights to demand product substitution.
1 - 20 of 63 Posts
