Do you want more Top End speed or Faster light to light speed ? the most popular is -1/+2 for faster light to light speed .
So what does that mean .
For example a -1/+2 means the first number is the front sprocket and the second number / is the rear sprocket . and the - (minus) number is how many teeth less there are than the stock sprocket . and the + (plus) number is how many teeth more there are than the stock sprocket. So a bike with a 17 teeth front and 43 teeth rear would need a 16 teeth front and a 45 teeth rear sprocket .
The effect that you feel with a -1/+2 sprocket set change is an increased rate of acceleration. But increasing the rate of acceleration draws more Horsepower.
By changing the sprockets you change the gear ratio.
A lower gear ratio of 3:1 (which is a actual higher numerical number) will bolster your bottom end for faster light-to-light speed, while a higher gear ratio of 2:1 (which is a actual lower numerical number) will increase the top end speed. And increasing the top end speed will always decrease the light to light speed. so you really cant have both .
A lower gear ratio is also referred to as , I have/need/did - Lower/shorter gearing .
And a higher gear ratio is referred to as , I have/need/did - Higher/Taller Gearing .
For Taller gearing to increase top end speed and gas mileage (willing to sacrifice a little light to light speed) most people will change to a bigger front sprocket only because its smaller therefore cheaper , and easier to install. For every 1 tooth "up" you change on the front, it is the equivalent to changing approx' 3 teeth "down" on the rear. and therefore may require a new chain length.
Hope this helps some of you with your Choice .
