Sprocket advice
12984 Views 27 Replies 9 Participants Last post by  Kaw'ee
Hey all i have been reading alot about sprocket changes people have done and was wondering if it would be right for me. Currently, the fastest my Z has ever gotten (downhill with tailwind) was 64. And I'm a pretty light dude at 125 pounds. It has never hit rev limiter at 4th gear because it just doesnt have the grunt to get there, and getting from 56-61 takes forever. So i was thinking about going down a tooth in the front to give it some more push. I realize this will decrease top speed, but with how it is now, I never even get all the way to redline anyways because of the lack of torque. In a perfect world, I was hoping this sprocket change would get me to about the same speeds I'm getting now or maybe slightly lower, just at a higher rpm but with the more fun in the low/mid range that comes with the torque. Will it completely kill my top speed? I'm not sure how drastic the sprocket changes are. I also read that it will screw with the speedometer, but I thought that the speedometer read from wheel rotation not sprocket? even if it does, would it make the speedo reading more accurate? or worse?
1 - 20 of 28 Posts
The speedo is read from the final output gear in the transmission, so a lot of things screw it up. I have a correction device, but haven't put it on yet.
A 13 tooth gear would be one lower, but might be too much, not sure because I haven't put mine on yet either. It might need the stock 14 gear in the front, and a rear gear with a couple extra teeth to do what you want.
Reactions: 1
Check this link for your speed-o question
http://www.z125owners.com/forum/kaw...speedometer-reading-errors-n-corrections.html
Thanks for the info guys! definitely cleared stuff up about the speedo. I guess the best thing to do about the sprocket is trial and error and see what I like best. Kinda leaning towards the 32 rear. The things aren't expensive so even if i hate it and go back to stock, its no big deal.
With larger rear sprocket, chain becomes an issue.
good point dlycan :wink2:
With a 32 tooth rear sprocket... (stock 14 front)
A Chain calculator will show a 101 link , and nobody wants to use a 1/2 link . So as long as your near the third notch back you should be able to slide the adjusters forward and use the stock 100 link chain
When changing the front to a 13 tooth , A Chain calculator will show a 99 links (actually needs to to shorter) but again, should be able to use the stock 100 link chain using the adjusters ...
With stock 14 tooth front sprocket.
30 tooth rear sprocket needs a 100 link chain
34 tooth rear sprocket needs a 102 link chain
38 tooth rear sprocket needs a 104 link chain
(Chains only come in equal number links)
13 or 15 tooth on the front and going bigger on the rear will change the total links required
See less See more
I've run a 32 with the stock front and stock chain. it fits, but very little adjustment is left. Theres still enough slack for adequate swingarm travel.
Acceleration was nice! I liked it alot, but top end suffered badly and I always felt like I needed a gear between wnd and 3rd in the twisties. A 31 rear on mine is near ideal. A slight, but very noticable increase in low end grunt and only a loss of about 4 mph on the top.
So what was your top end with 32 sprocket? I was thinking of doing 13 and 32. I would like to make the front end come up easier on 2nd gear wheelie.
I have a 13 now and my speedo is off by 5 mph.
Stock sprockets setup was best for me. Went a size taller tire in the rear and went +2 in the rear to get as close as stock ratio as possible.
All other sprocket combinations sucked. -1 was completely horrible. Felt faster until I raced my buddies stock z and it walked me hard from pretty much the start. Went back to stock and was dead even.
-1 in the front should have given you better acceleration, made a huge difference on my KAYO and let me get into 5th on the straights where before I was only approaching 5th at the end of the straight.
Might have to rethink what I was going to try with my Z. I know eventually I want to go 120/80 rear tire, maybe I need to run the larger tire with the stock front sprocket???
My speedo was off and I never used a gps to verify what it was. But it couldn't hang with a friends stock z on long straights. I'd walk him pretty hard til mid 4th gear, then he'd start making up distance and end up walking me. When I hit the limiter, he was still pulling.
Sounds about right. Since you gain acceleration you will loose top speed.
I do not race this bike even though I know it would be tons of fun. I just wanna be better on second gear wheelies then I can move on to do it to my other bigger bike. 🙂
I was thinking of doing 13 and 32. .
With 13/32 the actual GPS top speed is 54mph. but your speedo will show 66mph
as long as your running stock tire sizes .
13/32 is the preferred Wheelie gearing :wink2:
13/32 is the preferred Wheelie gearing /forum/images/Z125owners/smilies/tango_face_wink.png
.[/QUOTE
Awesome! Thank you. The actual mph is not too bad.
I am probably going to be much slower than that since I have a 130 tire width in the back. 🙂
See less See more
Twas years ago. 1971. I had a Honda CL 450. To be quicker I went 2 teeth down on the front sprocket. No need for a new chain.
Transversely.
I’m thinking two teeth removed from the rear sprocket would increase my my top end. Also no need for a new chain.
call it Wisdom of the ancients.
Anyone know what chain link i would need for 15T front sprocket and 35T rear sprocket ratio on the z?
Will use a 104 link chain. (maybe even a 102 link)
Chain length calculator here for future reff;
Unless you have a reason ?
Putting a higher gearing counter sprocket is defeating putting a lower gearing sprocket on the rear.
You could just put a 33T on the rear and have the same gear ratio as going 15/35
And will need a 102 link chain
Or maybe really want a 13T counter for wheelies since you want a 35T on rear .
and then will need a 102 link chain
Rectangle Font Parallel Pattern Number
See less See more
ahh i see, huge help here. Im trying to get a bit more top speed AND more acceleration but would much rather have more acceleration over top speed for wheelies but i do want a bit more on my top speed if that would be possible. what sprocket ratio would make the most sense for that?
1 - 20 of 28 Posts
