I just installed a set of R&G sliders on my wife's bike. They look like a nice piece of kit, and they attach in several places, which should make them more solid than ones that only bolt to the engine cover, but there is a tricky bit getting the right hand mounting plate to fit properly. It seems this was designed for the automatic version of the bike, and doesn't quite clear the clutch cable bracket. That means you either have to Dremel a recess in the mounting plate to accept the bracket, or put some spacer washers under the plate to move it 2-3 mm out from the engine cover. No big deal... unless you don't have any washers and the hardware store is closed :)
R&G or Piranha would be my suggestions. Most the others bolt straight to the cases and that's asking for hefty bill if you lay it down. The main support on the other two is through the top motor mount
