1 - 9 of 9 Posts
Hello everyone. I was just wondering what else would i need to buy when installing a big bore kit to make the bike run smooth without issues? Any info is greatly appreciated. Thanks!
Everything I've bought from @mnnthbx has been quality. get the HD clutch with the 143 bb kit and stroker crank that makes it a 155 and the aracer and you should be good to go. Also the o2 eliminator from kawasaki brad.
It's not completely necessary, your bike will run without it. Here's from the site
Why do I need an O2 Eliminator?
• Running an aftermarket exhaust? This adds approximately 3% fuel to help the bike run better and cooler. No more check engine light. No fuel tuner required.
• Running a fuel tuner (Power Commander, Bazzaz, Autotune, etc)? The stock O2 sensor and ECU will get a sniff of any fuelling adjustments and try to cancel them out. With an O2 Eliminator your engine runs on the fuel map you want it to. Not a half version.
• An absolute must for any Autotune module. Better accuracy and more consistent results when Dyno tuning.
• Did your stock O2 Sensor burn out (they all eventually do) and you don’t want to spend a couple hundred bucks to replace it?
• Stock bikes are designed to run on the knifes edge of “too lean”. A very slight fuel enrichment can cause a noticeable improvement in overall rideability, throttle response, low end torque, and operating temperature.
1 - 9 of 9 Posts
