Check with MNNTHBX. He's forum sponsor and makes an integrated tail/turn plug n play unit.
His website: mnnthbx.com
I am not aware of a relay or other unit that would allow you to retain the stock light and add the turn signal functionality. That would be a nice option but I am sure it would require some custom wiring, as well as installing amber LED'S inside the stock light. It could be done, but as others have said, many options are out there for aftermarket tail lights with integrated signals.Wondering if there is some sort of a module/relay that would add turn signal capability to the two "Z"s that the tail light/brake light has. (i.e. one would flash for turn signal).
Really like the stock tail/brake light but want to clean up the rear end and don't want to replace it with one that has turn signals.
could you not use the red lights already?I am not aware of a relay or other unit that would allow you to retain the stock light and add the turn signal functionality. That would be a nice option but I am sure it would require some custom wiring, as well as installing amber LED'S inside the stock light. It could be done, but as others have said, many options are out there for aftermarket tail lights with integrated signals.
All the LED's are on one circuit board. You would have to re engineer it. Like others have said, the R&D has already been done by the vendors on this site. Check them out. They have great products.could you not use the red lights already?
are there not turn signals on cars that work like this? (red blinking lights for turn signal, same lights as brake/tail)
Exactly what these guys have said. The circuit board for the stock unit only has the brake/running light functionality. In order to "integrate" the signals into the stock unit you would need to re-design the board with extra LEDs and the wiring to go with it.All the LED's are on one circuit board. You would have to re engineer it. Like others have said, the R&D has already been done by the vendors on this site. Check them out. They have great products.
