Found this on a Japanese site. Price is at 64,000 yen (tax included) equates to roughly $610 USD at this moment in time.
Link: Z125 PRO OHLINS ?????? ??????????2A105?
This is what I gathered from clicking the translate button.
high-end model corresponding from the street to the circuit racing
type S36PC1
between the axes: 239mm
piston diameter: Φ36mm
effective stroke length: 40mm
standard preload amount: 7mm
spring pre-load: stepless adjustment
pressure side damping force adjustment: 14 levels of adjustment
pressure side damping force adjustment control allows the strength of the "shrinkage" at the time of dumping
hold out a sense of acceleration, beyond the unexpected gap will be reflected largely on the reaction rate of when
spring has 60281-238 is incorporated into the suspension body
60281-23 (rate 145N / mm, free length 130mm, recommended in the following weight 80kg)
comes of spring will be below
60282-08 (rate 160N / mm, free length 135mm, recommended more than body weight 80kg)
Street and circuit driving is possible Setteingu of spring according to the situation, such as
commodity domestic regular manufacturer's warranty because it is regular goods, but their imports etc. are not eligible
