1 - 10 of 10 Posts
Hello,
I have a quick question on the comp s exhaust, do you use the old manifold gasket from the stock exhaust? Mine runs weird when I put the gasket in and makes a weird noise between 5000-6000 rpms. Just want to know if I should use the old buy a new or eliminate it.
Thanks for the help!
when exhaust is cold
start the bike, cover the exhaust outlet with your hand
if you hear air blowing out from the front gasket the gasket is bad
if its really quiet and you hear nothing the gasket is good
noises you may be hearing could be something vibrating
possibly the exhaust
maybe make sure nothing is touching anything or its all tight
also look at your rear pegs, they bounce around when riding could always put some tape on them or lock down and do a test ride
I rode my z around the neighborhood without my helmet the other day and noticed that the license plate vibrated loudly at certain rpm on the tail tidy I had installed. Never noticed that with my helmet on. Piece of foam didn't fix the noise.
Which tail tidy do you have ?? Have you tried seeing if everything was tight ?
I have the Mnnthbx tidy. Well designed imo and yeah, it was tight. Just the right rpm set up a vibe that caused the plate to vibrate against the mount. I used some foam leftover from a shorai battery that I stuck behind the plate and no more noise.
1 - 10 of 10 Posts
