Hey everyone - new to the forum, but been on the FB group for a bit. I designed a new oil cooler bracket for the Morin piece, which mounts to the frame instead of the head. It also provides a fairing support for those of us with an aftermarket intake.
I've checked air pressures in front of/behind the cooler in this location to confirm a differential. So airflow should not be a problem. Once I actually connect the cooler, I can run thermal imaging... but this might be a week or so before I get around to it.
If anyone is interested in one or has questions, let me know. I have a couple left over, and I may consider making another batch if there is interest. I'm not a store/part manufacturer, just a Z owner who made some parts for the community.
Note: Will not fit if you have another fairing brace, or the stock airbox. This bracket uses the stock mounting hardware from the OEM airbox (bolts + rubber grommets for the fairing pins). It comes from me as bare aluminum.
