1 - 6 of 6 Posts
Does anyone know of a lowering kit for the rear that exits without any stretching? I know that composimo has a 7inch lowering link but it requires the bike to be stretched.
Thanks in advanced.
front is easy, just slide up forks
composimo has listed on the website 3-4 inch lowering mounts too
but all the times I contacted him asking about those, all went unanswered
my guess is its not going to happen
the couple aftermarket rear shocks out there don't really list the length either
guess you can only stretch then use that 7 inch lower mount which is super low
I tried it for a second and took it off
you need to stretch really long, for the tire not to hit the license plate
I only went back with a 4 inch stretch
My front forks have been slide down as much as I can without hitting the handle bars.
What can the composimo front lowered kit do that you can't do just by sliding the forks down?
I also have messaged composimo on Facebook about the lowering link for the rear 4" but haven't got a reply either.
the ones I've seen on the grom
require a new bar setup, the forks get special caps that are around 3 inches tall that drops the front 3 inches
and you could also slide up the forks a touch too
but the special bar setup is pretty expensive
1 - 6 of 6 Posts
