Should I do the tps reset after installing a new exhaust. And it's there an ecu reset procedure Aswell or only tps for the z
26555
When it says ignition switch am I using key or the kilswitch. Also been told there is no ecu reset?
Humm, Actually very good questions
there's a video of a guy doing it, but he's making a judgment call also because the service manual doesn't go into detail
I'd have to think its the key because of the key-on/ key-off cycles
Might not be an actual reset, but if there's a procedure after a new one installed, should be somewhat like a reset ? A worth a try
And does ecu require the same plug grounded as the tps
Another gray area, but I fact its not included in the flow chart like the TPS has I've always assumed NO
Never seen or heard of anyone having to reset anything for a intake and exhaust
