Hi I just got a 2018 z125 pro and previous owner had a kevtek engine crash cage not installed. I would like to install it and
Bicycle Bicycle tire Bicycle fork Tire Bicycle frame
I have tried to contact kevtek and they have not responded but does it use the existing engine mounts or is there additional hardware I am missing? Can someone who has one please let me know 馃檹
Yes, you can re-use the mounting bolts. The one bolt you will need is used to connect the two halves together. It should be a size M10 x 1.5 and its roughly 20mm long, but you can use a slightly longer one if you can't find one that short. Also, it should be a hex bit head: 8mm, because theres no room for a regular socket.
The engine mount torque spec is 44ft-lbs.
Mine looks like this:
Finger Household hardware Nickel Thumb Body jewelry
Thank you!
Yeah, happy to help! The cage itself is pretty sweet. I use my bike mostly for gymkhana and dumping the bike 5-6 times every session is pretty much a non issue for me. Also you can always get longer bolts if you want. They are M12 x 1.25 if you do.
Tire Wheel Fuel tank Vehicle Automotive fuel system
Installed 馃憣
