I got the kamikaze head to work with the z125. Heads are very similar but the intake flange is backwards so in order for this to work you must sand the flange down and tig weld material back on and sand it flat and drill and tap holes for the intake. Job wasnt incredibly difficult but you must have good tig welding skills to make this happen other than that everything else is a direct swap except for the engine temp sensor that has no place so you have to make a hole and tap it.
The specs on the head are
28.5mm intake valve with a 21.6mm titanium exhaust valve.
Finished up the job and test rode very happy for the work i put into it bike has lots more mid and top end. low end sucks but with big valves and a big cam thats expected. idle is a little tricky u have to lean it out to keep a nice idle. I have rollers and a roller style cam coming in with more lift and duration.
