I was also curious about this. Just dont logically see paying $100+ for a little k&n breather filter and a piece of tube. If no ones knows off the top of their head, i will take it apart this week and check it out.
Very nice you have a link to that filter. Looks goodNo need to replace the hose just break the glue around the original hose that attaches to the air box. Pull the hose out of the air box and you will notice it has a lip on the end which is perfect then go buy a filter with I think a 2 inch diameter make sure the lip slides in the filter and whalaa.
Thank you sirThanks for that!! I just order the air filter! I run that exact filter on my dirt bike lol.. Once it comes in i'll be dismantling the air box!
The air filter is By "Uni", just ebay "50mm uni air filter" and a schwack of them will come up and for around $20. Great air filter and i ran mine on my dirt bike for a year now, you just need to pre oil them before installing.
your about right just went to the site and looked up that throttle body and it states "OEM stock size is 24mm, Chimera is 26mm! ALL OEM Sensors are intact". I will double check just incase.
Looks like the Dayco C71289 radiator hose will fit it has a inside diameter of 1.34" and already has a bend so all you need to do is cut it accordingly. Same hoses as a lot of the Grom guys are using to Mod their airbox.
Looks really nice sticking out from behind the panel and yes it adds quite a bit of noise but it sounds good.****... thought about that the other day, but i was to lazy to pull the box... looks awesome, nice job!
Is that the 6" or 4" uni air filter? Any noticeable difference in acceleration?Looks really nice sticking out from behind the panel and yes it adds quite a bit of noise but it sounds good.
It's the 4 inch. And yes I have. Quite a bit for a $20 upgrade. I would not get the 6 inch though the six would stick out to far.Is that the 6" or 4" uni air filter? Any noticeable difference in acceleration?
