Are you a member on this forum ?! This headlight retrofit looks dope as ever !
Oh okay, see I knew it didn't come like that ! That looks dope though. Did he do it himself or get a shop to do it ?It's my friend's.
Where would one find this kind of headlight, but with green accent lighting? I really like the way it looks compared to the one that comes on ours. I know we can get the plastics off ebay or through Dark Knight possibly, but the actual headlight is what I've never seen before. Another question for your friend would be does this remove the ability for high beams?It's my friend's.
My RX-8 has HIDs, but it's only for the low beams. Then a separate bulb for my high beams (now LEDs). My brother's '13 Camaro has the kind that the cutoff line flips out of the way for the high beams to work. Which if this setup has those kind of lights, I REALLY want that kind over our stock lights.I don't think it should remove the ability for high beams as you can install lighting in there that'll function with high beams off of one bulb. If the projector allows for a block-off for the highbeam perhaps ?
My 13' BRZ is like that as well, that's why I was hoping they were like that too so I made the assumption lol ! If it is, that retrofit is probably pricey. Going to involve a bit more wiring as well.My RX-8 has HIDs, but it's only for the low beams. Then a separate bulb for my high beams (now LEDs). My brother's '13 Camaro has the kind that the cutoff line flips out of the way for the high beams to work. Which if this setup has those kind of lights, I REALLY want that kind over our stock lights.
Could you ask your friend where he got this setup? I would really like to get this instead of stock.No,my friend's highbeam still on the bike.
Because HID, highbeam brighter and farther.
