just lift an edge with your fingernail and oull it off slowly, roll the glue off with your thumb, waxJust trying to cleanse my Z of any uneccesary fluff, any help on how to get the Z125 emblem off of the tank shroud?
LMFAO.or use an old screw driver with a screwed up jagged edge, slide it along the paint a good 2" and tap it under the emblem with a good size framing hammer. when it lifts just keep pounding with a hammer. pulling it off might peel the paint so big hammer is the answer. then wax
Thanks James. I appreciate your help.You can warm it with a blow dryer to make it easier.
this is the way I debadge any of my customers vehicles only I have a heat gun. Low heat and it comes right off. Little bit of goo gone on a rag t remove any glue that may still be there. Then wash the area to remove the goo gone and wax.Hair dryer and dental floss pulled slowly behind the emblem,Easy stuff, then use Wd40 or Goo Gone to remove the left over glue with your fingernail.
Wax and you are GTG.
