1 - 2 of 2 Posts
A 10a mini fuse keeps blowing on my 2017. It's worked fine before but I turned on the battery, let it prime, and then pushed the one button while revving. I have to rev due to the upgrades my husband and I made. We added underglow lights, new front and rear turn signals, and changed the front headlight. We also added different mods. I never had to rev the bike to start until after the underglow lights due to its parasitic drain. Now the same fuse keeps blowing. Please help.
With all those changes I would unhook all of them, Then hook them back one at a time and see which one blows the fuse. And sounds like you hooked the underglow lights to a constant hot wire if you have a parasitic drain from them. Run the power to a "switched" (only when key on) hot wire and do that last if your issue started after installing them
1 - 2 of 2 Posts
