Hi All,
My fuel pump doesn't always seem to "prime" when I turn the key on and flip the ignition switch on. Tonight, for example, I turned the key on first, then flipped the ignition switch, and I didn't hear it prime. I turned both off, and then flipped the ignition switch first, and then turned the key on, and I heard it. I fired it up, and turned it off after a bit. Then I tried again, and heard the pump prime for a brief second (not the normal 3ish seconds). Is this normal behavior? Should I always be able to hear the fuel pump everytime I turn the key/switch on?
Thanks!
Thanks!
