So last night doing wheelies I looped my z out. As luck would have it i still had the fender on so it took all the damage. After seeing what i did to the fender i decided to take it off all together (which i was planning anyway). After a beer or two I started disassembling the fender as I was going to buy an eliminator and I wanted to keep oem blinkers. When I took the fender apart tho I noticed that the holes on the back of the licensee plate holder matched the holes where the fender bolted on. Also I noticed I could take the red reflectors off and install my blinkers. I used a washer and the oem screw that was in the blinker. I took some rubber washers and some 90 degree brackets I had from another project and boom fender eliminator.
It needs a plate light but otherwise its all set
if you have any questions don't hesitate to ask
