1 - 3 of 3 Posts
2021 kawasaki z125 pro
After riding for a few min in all gears when at low rpm it will start to bog out but stops when I get into higher rpm and when I come to a stop it will just die out. A couple days ago was low on gas at a **** part of town and filled up at a **** gas station can this be a result of bad gas?
A couple of weeks ago I changed oil and put HD clutch springs in and new clutch plates and it has been riding fine until a day ago, cld something possibly came loose that would cause this?
I have an exhaust and intake with the aracer rc mini5 and af1, nothing is coming up in malfunction or has it thrown any codes
Bogging down could be bad fuel. Bad fuel pump ( never let it run dry), or spark plug / coil issue. There are other things also but those to me are the top of the list.
Does your bike have a whine to it? If so that might indicate bad fuel pump. Also check your spark plug and that the coil is plugged in all the way in.
Has no whine or any indicating noise other than it bogging down and its never been ran dry. I'll check the spark plug and make sure everything secured correctly.
1 - 3 of 3 Posts
