The CRG blindsight mirror will mount directly to OEM bar end.
D Drew Kazee · Registered Joined Jul 22, 2016 · 4 Posts Discussion Starter · #1 · Aug 7, 2016 Only show this user The CRG blindsight mirror will mount directly to OEM bar end. Attachments crg .jpg 40.7 KB Views: 435
Zmike125 · Registered Joined Jul 1, 2016 · 346 Posts #2 · Aug 7, 2016 Only show this user be careful the bar ends are plastic and do pull out they are in pretty good but wonder if the weight and vibrations could cause them to come loose over time
D Drew Kazee · Registered Joined Jul 22, 2016 · 4 Posts Discussion Starter · #3 · Aug 7, 2016 Only show this user That is a concern that I will watch for. Pulled this mirror off of my Vespa to try. thought I had had an extra bar end adapter but couldn't find it.
K KawiGirl · Registered Joined Oct 30, 2015 · 466 Posts #4 · Aug 7, 2016 Only show this user Should be fine if you just quickly check it once a week for looseness
HardRacing · Junior Member Joined May 24, 2016 · 447 Posts #5 · Aug 7, 2016 Only show this user Zmike125 said: be careful the bar ends are plastic and do pull out they are in pretty good but wonder if the weight and vibrations could cause them to come loose over time Click to expand... . Agreed. For just a little more money, you can get the Alum. Bar Ends adapters, specific for the mirrors. So they don't fall off our break. .
