1 - 20 of 30 Posts
Doing a complete part out of my Z. More than most. I am not selling the complete engine. It has been torn down to the very last bolt in case someone needs something internally like a shift shaft or fork or something. Only thing I'm trying to keep as a set is the lock set, everything else is being sold individualy so let me know if you need anything.
And the aftermarket. This is everything I still have left.
-Pro Circuit T-6 exhaust (w/ 18mm bung)
-Takegawa Super Oil Pump
-Öhlins complete rear shock w/ custom shocker yellow powder coated spring
-DMP powergrid smoke integrated LED tail light
-Brembo P34 caliper. Titanium color. Comes with a set of bronze Shiny banjo bolts and a new in box, polished Goodridge banjo bolt
-New Rage Cycles tag bracket w LED tag light
-Brand New in package TBparts HD cam chain
-Brand New in package K&S anodized black banjo bolt hydraulic rear brake switch (for use with aftermarket rearsets that don't accept OEM spring such as Driven)
-CRG SC2 complete perch & black shorty lever combo (comes w new extra Replacement lever)
-CRG RC2 black shorty brake lever (will include an extra replacement lever)
-Driven Racing Halo fuel cap. Black/Silver
-Driven Racing black valve tappet covers
-Driven Racing black endurance cups (service of 4)
-New in Package, K&S turn signal adapter wires
- 2 sets of Competition Werkes GP style aluminum passenger pegs. 1 is new and they are polished. 1 slightly used and they are black
- Bully disc lock with alarm
-Works Connection Polished front brake reservoir cap
-TBParts polished oil filler cap w oil temp gauge
-Motion Pro KLX110L clutch lever used for one ride
-Cycra Racing Series One handgaurds. Never used. Black bars w black shields
*** If interested in anything shoot me a direct message either here or on FB. Will be happy to answer any questions and provide pics when needed.
What stock parts are you going to have? Might be interested in a set of front forks and stuff. Might want a set of stock wheels as well (with disks and sprocket, etc.). On the east coast so shipping may determine a yes or no on this stuff.
I sold the forks already bc I had them set up with öhlins internals. I pretty much have
-anything electrical (speedo, relays, handlebar switches, ECU pre and post recall, ect...) other than the stator
-swingarm
-all plastics
-headlight,
-any bracket on the bike
-top clamp
-stock fork internals and fork caps
-throttle tube
-fuel tank
-fuel pump
-brake lines front & rear
-brake master cylinder front & rear
-rear brake caliper
-cylinder head (valves still in but no cam)
-levers
-cam gear w the decompression weights still attached
-intake manifold,
-fuel injector
-injector nozzle
-main fuel line
-both side case covers
-primary gear
-shifter shaft and any other interal shifting related parts
-exhaust
-axles
-lock set (fuel cap, ignition switch and seat lock)
-passenger pegs
-clutch perch
-front brake rotor
-wheels that have been powder coated shocker yellow
Forgot a couple lol
-one way starter bearing
-starter gear
-idler gear
-starter Motor
-output shaft
-shift drum
-shift forks
-transmission gears
PM Sent
How much for the speedo? I want to pull it apart and see if I can solder in a flasher that doesn't care about LED vs incandescent blinkers.
Discussion Starter · #12 ·
Asking price is $190. Perfect condition, not scratched up at all, no discoloring or cracks or anything of that nature
Thanks, but I was hoping the cluster was in 'less than perfect' condition. I don't want to bust up a perfectly working cluster.
How much for rear shock says yellow but looks green
OK I saw the picture power coded
Do you have both springs
you firm on the price 395 Is what I paid new for mine lk to put one on the wife’s call me 630 600 1538 will
Hmmm, message me a price for the Brembo front caliper (and brake line if you have it) please Bryan
Discussion Starter · #20 ·
Unfortunately both of those have sold.
Didn't upload pics of everything but, the complete listed is below.
Here is an update list of aftermarket items still available:
-K&S smoked flushmounts led front turn signals (will include adapters so you will not have to cut on your stock signal wires)
-New Rage Cycles flush undertail tag bracket with LED light
-Competition Werkes GP passenger pegs. Polished set and black set
-green D'Cor wheel stripes
-CRG SC2 clutch perch and lever combo w/spare lever
-CRG RC2 black adjustable shorty brake lever w/spare lever
-Driven Racing Halo gas cap
-K&S hydraulic brake light switch (banjo bolt)
-TBparts HD cam chain
-13,14,15 tooth front sprockets
-30 & 33 tooth rear sprockets (33 is a black Bikemaster sprocket)
1 - 20 of 30 Posts
