1 - 3 of 3 Posts
Just installed Bazzazz zfi and auto tune. Checked connections 4X everything good just that light is on? Did i do something wrong? Or is o2 sensor they provided bad?
Thanks in advance
Unfortunately the light will stay on when using the AFM.
But once you have built your map take it off and install the stock 02 sensor.
After some time riding the light will turn off.
Make sure you leave the 02 eliminator connected.
Also you will need an 18mm to 12mm 02 adapter.
1 - 3 of 3 Posts
