chain slip.
227 views 1 reply 2 participants last post by  Kaw'ee
#1 ·
Hi guys I have an issue with my chain slipping under hard acceleration. I recently changed my front and rear sprocket and chain. I’m noticing metal shavings in the front sprocket cover and rear rim. Could I have installed the wrong size chain? Is it the clutch? Any insight is much appreciated.
#2 ·
Could also be the wrong sprockets or the chain alignment, and or wrong chain slack setting.
If you have a good way to measure PITCH & ROLLOR DIAMETER, use the #420 dimensions on the chart.
Look on the box or packaging for the number 420
or if you have the link where you bought it from look there. But still try to measure it if not from a reputable source.
