21 - 36 of 36 Posts
Discussion Starter #21
@Kaw'ee, what DID you do? Any pictures? My plan is to delete the canister since the Hoedar wont ever actuate the purge valve...
I thought the Z had a vent in the gas cap to let air in and that tube was basically just an overflow for the guys who put too much gas in when filling up at Costco...
Pic 6 in OP is what i did but have a hose coming out of a aftermarket cap now.
The cap works as shown in pic 1
The overflow hose is the lower level hole in tank front/left as shown in pic 2
Discussion Starter #22
Sounds like The purge valve needs to stay wired or check engine will come on. Or I read you can use a resister of the same value thing as a way to eliminate the purge valve. Remember seeing the resistance value in the service manual, but didnt research it much due to my CEL not working anyways.
Discussion Starter #23
Because this vent is supposed to flow into a closed canister I'm guessing the location is designed to not allow liquid into it at all. Based on the schematic Kaw'ee posted it looks like the vent line in question is raised above the floor of the overflow chamber, while the overflow line sits on the bottom of that area to grab the spilled fuel.
Ya, the cap does all the venting the rubber vent hole up top excepts the nipple on the cap.
Yeah, your picture really helps. I've never noticed that little pass-through. From the seat the cap obscures it.
What's your new gas cap look like? I don't think I've seen a post on it yet. ;]
Discussion Starter #25
Ya, to busy with G-Pop daycare..Wife broke knee and shes in a hip to ankle brace so havent had time for anything last 2 weeks except all her comments. I will snap a few !! Carb still looking good waiting on pilot jets now... But shifting into second gear full throttle is breaking the tire loose with my 230lbs on it so still have high hopes ...
Reactions: Ando
Great info guys! I'm likely going to run a Hoedar and I don't think it actuates the solenoid. This seems problematic to me... I have a non-Cali stock ECU I can probably swap over from my wrecked Z, or I can install the Hoedar, or remove everything and just leave the solenoid in place.... I like the @mnnthbx idea but not sure if that is going to end up trapping gas vapors.
I guess I'm not even sure what the purge valve accomplishes. Crazy emissions stuff.
As designed: Alleviates gas tank vapor pressure into emissions canister. Occasionally dumps fumes into intake.
Without purge: Alleviates gas tank vapor pressure into intake... potential to pull vacuum on gas tank?
Without purge and vented to atmosphere: Alleviates gas tank vapor pressure into atmosphere. CA cries itself to sleep, bike runs fine. Life is good?
As Kaw'ee requested I've finally completed a bypass plug that I'm 99.9% sure will work. Plug and play with exact fit to the stock harness. Duplicates the signal that the stock purge valve would produce so your ECU doesn't know it's missing. No check engine light! Since I don't have access to any CA models I'll need some volunteer testers. Kaw'ee, yours is in the mail since it was your idea anyways.
Volunteer tester criteria:
Regular forum participant
Somewhat mechanically inclined
Z125 CA model owner
Desmog/race/carb conversion or for whatever reason, you need to be performing/have already performed this mod
Willing to ride a minimum of 200miles within a month of receiving and installing the prototype
Willing to provide feedback
If you're interested in testing please PM me or email [email protected]. It will cost you $15USD including shipping to your door (which will be about half price of retail when they finally go up on the site). When you're done it's yours. If it doesn't work I'll keep sending you revisions on my dime until it does (again, I'm 99.9% sure this will work).
Discussion Starter #29
I love volunteer work :p
After my first 4 run cycles to clear the CEL and for the first time in over 2 years ....
NO CHECK ENGINE LIGHT !!!
Now to the "Destructive Testing " phase ... :p Braaap .......
Discussion Starter #32
I figure if Kawi can't break it then it probably can't be broken and no further testing would be required. :LOL:
Day ain't over :ROFLMAO:
But it passed my 6hrs under water test and no CEL
And 3mins of continuous impact against the side case .
So your lookin good to go so far (y)
Coming up on a week. By all means be honest. Is it working or not. What's wrong, what's right, what recommendations do you have?
I'm not trying to pass the buck. I have personally tested this form factor with the smog pump bypass aka clean air mod aka air switching valve delete for the ZX10, ZX6, Z900, Z800, Z650, Ninja650, etc. Works well, but I don't play in an off road environment much lately. It's also a substantial increase of energy.
At the end of the day it's not an earth shattering mod. But discreetly and seamlessly bypassing electrical quirks while modding is one of my favorite things. How's that working out for you?
Discussion Starter #34
I haven't hit your 200mile mark yet, but I'm at 172 as of today. was going to do another 30mi tomorrow.
As to overkill the "Destructive Testing " phase
I have been cycling the key off and on at every stop, so at least 50 key cycles and not a single blink at all has shown and I'm watching specifically for the CEL light
Gotta say its ready for release in my opinion. (y)
Of course will contact you immediately if the CEL so much as even blinks
Now onto the VDS By-pass for those that dont want to gut the sensor and only want temporary by-pass it while stunting or off roading but want it on for regular daily use :unsure:
Aww shucks. The 200 mile was pretty much a baseline and not the rule. 200miles on the highway and 200miles in desert are very different things.
Looks like you put it through a fair bit of rigorous testing. I really do appreciate that.
21 - 36 of 36 Posts
