1 - 2 of 2 Posts
Battery OK, side stand up, in neutral, ignition on, bike doesn't turn over. I believe it is the starter switch. It had intermittently stopped working last year. Starts up just fine if I bump start it. Is my starter button or engine cut-off switch the likely culprit? Is it easy to replace? Thank you. 2017 Z125 Pro, about 12,500 km.
If battery has 12.4 volts with key on, then Yes, check battery connections !!! Test starter button, engine cut-off switch & starter relay with multi meter or just a test light for powered
If no volt meter , jump the battery with car battery to test if its the battery STARTER SWITCH.JPG KILL SWITCH.JPG STARTER RELAY TEST.JPG
Reactions: Ando
1 - 2 of 2 Posts
