1 - 15 of 15 Posts
My Z runs good on flat ground but going up hills it slows way down. If I install a 134 cc big bore kit will it fix my issue? Just cyc, piston and rings was I all I wanted to do.
You didn't say if your still totally stock, But a BBK alone will probably not get you where you want.
Count on $800.00 + to make a significant improvement
See this thread for reference
The 143 and a tuner will make it an entirely different bike. We use and sell more of these kits than probably anyone in the US. The stock head is for sure the weak link on the Z...
Discussion Starter #5
Ok i will get the 143 base kit w/o primary and striker crank. The piston looks cheap compared to stock. Does it last? Also should I get a Bizzas fuel mapper? What else should I get?
yes you will need a tuner either a direct ecu such as aracer or piggy back system (bazzaz, power commander, etc). I believe if you buy the bazzaz and the bbk from mnnthbx they will provide you a tuned map.
The stroker (155) is great for sure, but it’s not required, as the standard 143 is light years ahead of stock. They’re super reliable. You can find several failures online, however poor tuning can blow nearly anything up. We’ve used and sold a LOT of these kits, and have never had a single issue, but we do have solid fuel maps we rely on (and provide free to customers).
@mnnhbx if I get the 143 kit with new head do you know where I can get installed?
99% do it themselves. With general fundamentals, it's actually fairly easy stuff. Outside of that, I'd locate a reputable local shop. We can take care of the fuel mapping on our end, so you simply need the parts on.
Discussion Starter #15
Does anyone know a shop in the Chicago/Milwaukee area that knows what they are doing to install a big bore kit?
1 - 15 of 15 Posts
