1 - 7 of 7 Posts
Zafm self mapper and AOD racing pipe with 18mm bung. I am missing the bracket that connects the muffler can to the frame so you will have to do some DIY to make a new mounting bracket. I do not have the instructions however the mapper is very easy to use and connect. You can find a Bazzaz AFM how to video on you tube that will walk you through it in less than three minuets
$200 shipped to the lower 48 usps priority mail. paypal.
Discussion Starter #4
Bazzaz AFM is sold. AR AODonly Racing pipe with 18mm bung still available for $55 shipped to the lower 48.
Would that fit the stock o2 sensor? If so i may be interested in it.
You should be able to get an adaptor to fit the 14mm OEM sensor. As a rule you can fit a smaller sensor in a larger bung but not the other way around because it removes the sensor tip from the exhaust stream.
1 - 7 of 7 Posts
