I recently installed the Bazzaz Z-FI on my bike and have had a continuing issue with the O2 plugin. There appears to be no issue with any connections but despite going through the clearing procedure per the manual it will not go away. The active code is 67 (O2 malfunction). I work at a Kawi dealer and have KDS3 but we are currently waiting on the proper adapter to come in for the bike. My main question, is the O2 piggy-back required since it seems to be what is causing the code?
Hey Mike I have the same problem.
The light just seems to stay on even when using the o2 eliminator plug from Bazzaz.
They should have supplied a small sticker for the dash to cover the light lol.
run the bike for 20 mins without the o2 adapter then shut the bike off and swap back in the o2 adapter and it should go away if it dont clear repeat the steps and it should go off. thats what i always did.
The installation is very easy. MNNTHBX has an installation video that walks through the entire process.
