I'm not a Racer, but I am an retired guy with experience as an Engineer and six or seven years experience having six 50 to 250cc Scooters. One concern with these smaller cycles is, of course visibility. I've added an Auxiliary Light Bar on the Front. Mounted on this bar are (2) LED Projection Lights with Hi, Low and Strobe beams. A WOLO Bad Boy Air Horn, Hopkins electronic Deer Alert, A control panel and 1 or 2 12VDC receptacles that aren't here yet. I added the mirror extenders because I couldn't see anything from the rear. The structure is made of brackets from the hardware and most are covered with black shrink wrap. Run a heavy (20 amp) fused wire from the battery to the front and attach a ground wire where the mounting hole was for the factory horn. All items run off the (+) Wire at the horn relay. P.S. The bar itself is actually a steel broom handle.
