1 - 3 of 3 Posts
After installing my ASV Shorty levers I pull in the clutch lever and engine stalls immediately when put into gear. I have tried adjusting the cable tension and does not fix the issue. Please help if you can. Thanks
Might be the clutch switch. Sometimes this issue is a kickstand switch, but if it worked before that, maybe not. I would expect good fit-up from ASV levers.
Pull the plug on the other end of the switch and stick a couple of ohm meter leads on the contacts in there. Should go from open circuit to closed as you pull the clutch in.
Thank you sir! I feel like a total idiot now! It was the kickstand of all things. I was getting so pissed trying to figure out the issue and considered taking it to the dealer. You saved me some time and money so thank you very much! Time for a cold beer :)
1 - 3 of 3 Posts
