Has anyone had this problem? I’ve only have the sensor for a week and it’s not working correctly
Are you using the Aracer Wideband O2 or reading the stock O2 through Aracer software?
Don't worry, at 25.6:1 AFR it wouldn't even run. Obviously a false reading. Just need to figure out what's causing it.
im using the aracer wb02 sensor with the aracer ecu. I’ve tried different things to try and fix but no luck
Did you remove the exhaust for any reason and if so did you change the gasket? Could there be a leak upstream from the O2 sensor somewhere?
Other than that it may be a calibration issue. What does Aracer have to say about it?
