ARACER AFR MODULE
187 views 1 reply 2 participants last post by  thormmy
#1 ·
I have the aracer mini 5 and the wideband AFR moduale on my Z. The only issue is the AFR or AF3 continues to draw power from the battery after the bike is turned off. Has anyone this problem and what did you do to fix it? Did you install a relay switch that you can power on? There is no help on the instructions.
