1 - 11 of 11 Posts
My first mod is definitely going to be brakes.
-Has anyone tried just HH pads with the stock caliper?
-HH pads with braided line and stock caliper?
-Brembo caliper and pads with stock MC and braided line?
I don't have any problems with the lever feel, just how hard I've got to squeeze to get it to bite hard. TIA
I have the Brembo caliper and braided line from Core Moto, works well, very happy. I also was not keen on the feel at the lever with the OE caliper/pad combo.
My front brake is a Brembo caliber with Brembo sintered pads, a Galfer disc, and a Core Moto braided line. I never use more than one finger on the lever (also non-stock) and it is all the stopping power I need in a non-racing machine.
Rear set-up is the stock caliber with Galfer sintered pads, a Galfer disc, and a Core Moto braided line.
HUGE improvement over stock, especially with upgraded tires...
JW
When we rode each others bikes with only one upgraded the first words we said on stopping was "Your brakes are GREAT/****" in unison
I am running Galfer Steel lines, Rotors, and Brakes and don't feel the the need to upgrade the caliper as the stopping power is immensely improved and I am racing mine. I barely squeeze and it provides so much more braking power over the stock setup.
I am not sure if upgrading to the Brembo would be that much more beneficial but I could be wrong. I saw this as I don't fully squeeze now with the current setup. maybe someone who has done the line and rotor upgrade first and rode around then added the Brembo Caliper can chime in.
I ran the Brembo P32 caliper & G-Craft bracket last season before sintered pads were available for the stock caliper. The original Brembo pads were not very impressive but after another $50 for Ferodo sintered pads it was a huge improvement over stock. After spending almost $300 for everything it should stop better!
However, this season I have more power and I'm again searching for a stronger front brake. I'm now testing a caliper & master cylinder from a 450 dirt bike. I'm still sorting it out but it's more aggressive than the 2 piston Brembo and lighter than the 4 piston Brembo. Not recommended for the street.
Better brakes are certainly appreciated in this part of the country with these things running around. At least these 2 were clearly visible in an open field. It’s a lot worse when they dart out from the woods. One finger on the front brake lever at all times is good practice on these roads...
JW
Following that useful tangent:
On occasion while riding alone in the country at night I'll give myself a challenge. Stop at every oversized mailbox, or every odd numbered mailbox.
Good test for panic braking and awareness and more than once I've missed my target which is a good wake-up call that I'm overriding my headlight. Deer are rarely as obvious as a mailbox so if you can't stop in time for a mailbox you should reconsider dusk/night riding.
My friends and I were driving out on some logging roads in a jeep and we spotted a deer to the left and suddenly one jumped out from a bush on the right. Had to break quite hard and thankfully stopped in time. That deer took its sweet time crossing and eyeing us down. Arrogant mo****trucker lol
Discussion Starter #10
Bumping this back from the dead.
I finally started upgrading the front brake with a speigler ss line and ebc hh pads.
The pads are still in shipping limbo but I installed the braided line the other day. I'd say it's definitely worth the time, effort, and money to replace. Much firmer lever and better feel through it also. Hard braking on the stock line could get the lever very close to the grip, the ss line has about 1/2 to 2/3rds that.
Unfortunately I never got an actual # of feet of stopping distance for a given speed on all stock brakes, but I plan on stopping by my local practice spot before I install the new pads to get some avg. #'s to compare the stock and hh pads.
I'll report back when I do(hopefully in a little less time in between).
Discussion Starter #11
Update with stopping distances for braided ss line, stock brake pads, and stock tires(front brake only, no engine braking)-
30mph=38ft
40mph=46.5ft
50mph=72ft
All distances are average of 10 stops.
HH pads arrived yesterday and I should have them installed, bedded, and tested by this weekend.
1 - 11 of 11 Posts
