1 - 3 of 3 Posts
I'm trying to install the AEM wideband sensor I'm getting power and the gauge is working but I need it to run through the hoedar ecu
The AEM Controller have Analog Output Positive and Negative pin ,you should wire it to original O2 connector.
The origional post is almost a year old... IIRC, Justin reached out to me on Facebook and we got this sorted out. You can wire in the AEM/LC-2 Wideband sensor directly into the stock O2 sensor plug. Only extra wire is ground either directly to the battery.
I ran the ground back to the battery, but during my install, I saw that the ground battery lead runs to the bike frome right behind the O2 sensor plug. I could have tied in there, but I already had everything cut and soldered to length.
1 - 3 of 3 Posts
